560 farmall
mike's 600
08-04-2005 18:10:04
What kind of cubes will i need to pull in 7500 lbs open class 3800 max rpm . with power to spare?
Can you get there with a 301 block?
Thanks
oliver puller
08-07-2005 06:06:03
 Re: 560 farmall in reply to mike's 600, 08-04-2005 18:10:04
I think you just need to build a big case or big moline that should take care of a 560ih. just me thinking.
mike's600
08-07-2005 12:05:45
 Re: 560 farmall in reply to oliver puller, 08-07-2005 06:06:03
I got one, and sold the other.
ChadS
08-05-2005 08:32:42
Well, thats the thing,, you do have to rev the IH up that fast to get alot of power and torque out of them to match a bigger engine say like in a moline, Let me rephrase that,, not match the torque, but give it more,, I have no idea if the IH 6 is possible of that much HP, never built a big cubed 6 like what your looking for. But, have seen some interesting parts that coud make a difference and cost you a bit less. I think you may need to look for a truck head. First, the truck heads are a heck of alot bigger in the ports VS the tractor heads, I have ported and polished both a truck head, and a tractor head, and all I can say is, that the truck head is still, much much larger than the tractor head, even after the tractor head has been hogged out. You do have more room to big valve the truck head rather the tractor head,, there is more area diameter wise in the compression chamber to make room for the bigger valves. Its like the LP head to the letter series Farmalls, but for the 6 cyl,,, it is a very high compression head,, and has to be used with flat top pistons, or maybe a slight dome on em,, Im thinking the truck head chamber is like a little under 3/8's deep, so, there may be a little room for domed pistons, custom cut to make room for the valves. The tractor head is a very deep chambered head, but a big dome could be made for them and fit, whether it breathes right after this, I cannot say, Me, I built a lite weight 460, to do more with less, so Im kinda backwards on the weight, but still going to run it hard on the rpms,,, I do agree with geting down to 4500, to give more weight placement, but at 7500, you will have alot to move around anyways,,, If your rules allow, why not look into a different engine to bolt in the 560? Like the Red diamond, of maybe even a 414 converted to gas? Mite save you alot of headaches,,, suppose you spend lets say 15K on a 301 style block, rev it up and it scatters all over the track,, but any engine takes that risk when going beyond what it was intended for,, but, the IH 6, can rev up,,, its more like a car or lite truck engine rather like a big ol 4 cyl tractor engine,,,, where the rods may give out,,, JMHO,,,ChadS
mike's600
08-05-2005 15:03:33
 Re: 560 farmall in reply to ChadS, 08-05-2005 08:32:42
Thanks for the help. I have been watching a fellow pull a 560 , and it never seems to run out of power.5500 6500 7500 and never changes it's tune. It's a sight to see pulling.It's rpm range seems to be up tp 7200 .
John in WV
08-05-2005 02:22:28
Heavier tractors with bigger CID engines with weight removed is hard for a 301 to pull aganist. Can you run gas only, diesel, turbo
mike's600
08-05-2005 03:59:10
 Re: 560 farmall in reply to John in WV, 08-05-2005 02:22:28
I'am going to run on gas.I would like 250 plus hp, what do you think?
Drew
08-05-2005 05:01:48
 Re: 560 farmall in reply to mike's600, 08-05-2005 03:59:10
I would try to get it down to atleast 4500lbs, if not lighter. For the engine, call Jeff @ Murphy's Motor Service 573-696-3655. He has built several 460/560 engines to do what you want to do.
