Help with electric fuel pump?!!
family traditio
08-04-2005 11:45:05
A few weeks ago I posted about my MM sputtering out and missing and popping while under a load. I thought it may be my pertronix ignition. Replaced it with original points, tractor would start and run for about 30 seconds and die like it ran out of gas. I pulled off the fuel line and started the pump and did not get any flow. I cut off the pump and a few seconds later a little bit of fuel ran out. I placed the fuel line in a jug started the pump and took the cap off the fuel tank and it had pressure on it. I grabbed a flashlight and looked into the tank and the pump is pushing back in the fuel tank and gurgling the fuel. Has my fuel pump completely laid down or do I have some other trouble? Thanks in advance!
farmall puller
08-04-2005 13:28:33
 Re: Help with electric fuel pump?!! in reply to family tradition, 08-04-2005 11:45:05
Has your tractor been running on this pump or did you just put it on? If your tractor has positive ground then your pump maybe pumping backwards.
family tradition
08-04-2005 14:42:44
 Re: Help with electric fuel pump?!! in reply to farmall puller, 08-04-2005 13:28:33
nevermind..... ..... the wires were on it backwards..... ..... .feel like a retard!
