Mt. Gilead Ohio Brush Pull August 5th Promise Last
Ohio M Puller
08-04-2005 04:32:04
Prize Money for all Classes
1st place 200 2nd place 100 3rd place 75 4th place 50 5th place 25
Division 4 - 5500
1) 18.4 X 38 maximum, Cut Tires Allowed.
2) Maximum 30 percent over RPM"s.
3) Drawbar 20 inch Max Height, 18 inch Min Length.
4) Maximum length 11 feet from center of rear axle to the furthest point forward, including weights.
5) Wheelie Bars and Kill switches are Mandatory.
6) No Year Limit on Tractors
see>Link
Super>Link Farm 9300lbs
NTPA Rules Apply
Farm Stock - 8500
1) 18.4 X 38 maximum, radials allowed. No cut tires.
2) Maximum 3000 RPM.
4) Maximum lenght 12 feet from center of rear axle to the furthest point forward, including weights.
5) Wheelie Bars and Kill Switches are Mandatory.
6) No Year Limit on Tractor.
see>Link
Farm>Link Stock - 12,500
1) 20.8 X 38 Maximum, Radials Allowed. No cut tires.
2) No water injections.
3) Stock turbo or stock OEM replacement.
4) Factory or OEM replacement injector pump.
5) Long sleeve shirt and full-faced helment REQUIRED.
6) 2900 RPM MAX. - NO BLANKET
7) 2900 RPM - OVER (3500 MAX.) BLANKET WILL BE REQUIRED SFI RATING BLANKET - SFI 4.1
8) Wheelie Bars and Kill Switches are Mandatory.
see>Link
Pro>Link Stock Diesel 4X4
1) ALL TRUCKS WHO PLACE IN THE CLASS WILL BE TECHED!
2) 8000lb limit (Dual rear wheels allowed).
3) No Nitrous, Propane, Alcohol allowed. 2 Diesel Only.
4) Hanging weights allowed, furthest point must not exceed 60" from C/L of front axle.
All weights must be secure; disqualification may be enforced if weights fall off.
5) Any single charger and Limited two charger configuration. The top twin charger must bolt
directly to a stock or ATS exhaust manifold. The atmosphere charger cannot have over 3"
inducers.
6) DOT tires, no studs, no cut or sharpened tires.
7) No aftermarket transfer cases or transmissions i.e. Drop boxes, Reversers.
8) Factory rear suspension may be blocked, no custom rigid suspensions allowed.
9) Must pull from Reese style hitch or factory bumper. Hook point must be at the furthest most
point of the vehicle. Hook point must be at least a 3 inch OD ring or clevis.
10) 26 Hitch Height.
11) Traction/Ladder bars allowed.
12) Exhaust must exit straight up or straight down.
13) No aftermarket heads.
14) Engine must be out of factory 1 ton or smaller pickup.
15) Trucks that place for the payout will be teched (to be determined).
16) Bell housing balnkets required for trucks that do not meet the Street Stock rules.
17) Drive shaft loops required for trucks that do not meet the Street Stock rules.
18) Water Injection permitted.
19) Fire Extinguishers required.
20) Track and Tech official"s decisions are FINAL.
see>Link
Thanks>Link for your interest
All Question should be directed to Adam Coleman 419 295 4592
