super m cam
drewtm
08-02-2005 18:32:07
what could i have done to my super m cam to get more power?
supermpuller.
08-02-2005 18:46:15
 Re: super m cam in reply to drewtm, 08-02-2005 18:32:07
Give Paul Marlett a call 765-938-2227 or get a IH 450 cam.
drewtm
08-02-2005 19:08:02
 Re: super m cam in reply to supermpuller., 08-02-2005 18:46:15
would a 450 cam bolt up the same or would i have to do some modifications?
ChadS
08-02-2005 19:29:56
 Re: super m cam in reply to drewtm, 08-02-2005 19:08:02
Sm-450 cam are the same grind, if you dont have the compression over 150, your not getting the full effect of the potential of the SM cam. Sm-450 cams are pretty good, its a match to the head. Run a compression test, if its under 150 you need to do a few things to get the compression up, you can mill the head, or find higher compression pistons,,, ChadS
