ChadS
08-04-2005 06:41:28
Re: Which Manifold for M? in reply to terryjd, 08-03-2005 21:09:17
Alot of tuning has to do with knowing your tractors engine, and its components that you already have. Trying things differently, and test it on the track. 130 is not a bad start,, so it may have stepped head pistons in it,, its when its like 100-110 you know you mite have flat tops. You can search the archives here in this board and find all sorts of info,,, The head casting number is under the valve cover. Some people like the dyna torques, some hate em, I have a Super M that likes them, Ive seen alot of close to stock HP tractors like a new tire,, contrary to popular belief, we have another M inthe family, that has a brand new set of 14.9X38 firestones on it, on 11 inch rims, it always works the engine at the end of the track, giets all it can handle form the amount of hook it gets, he runs 17psi of air in them to help keep the bars from folding back so much, and it does seem to help,,, Id say the tires you mentioned mite help a bit,,, on the tracks you spin out on, they just mite give you a little more bite and not dig so much and put dirt infront of the pan and stop you sooner. Ive got quite a few sets of good used pistons that mite help out the budget,, I keep all the pistons and pins from the ones that come in for engine work, everything from firecraters, to stepped heads,, even some flat tops too,,, Really, to get the most out of it,, you got to make sure everything is good,, every little thing helps, especially if its broken, Give it a pre trip inspection, check all the things you usually dont look at in a regular tune up,,, check your valve lash,, timing settings, look for vacuum leaks, and broken parts,, Id bet youll find something,,, ChadS
