copper head gasket
Pullin A
08-01-2005 00:17:48
Where can I get a coppper head gasket for a late A? I tried the 60 and the A gasket and neither seem to hold very long.
JDGnut
08-01-2005 14:48:19
 Re: copper head gasket in reply to Pullin A, 08-01-2005 00:17:48
Pulling A.. I have some Rubber Coated Copper Gaskets Head Gaskets... They recommend O-ringing them.. so I haven't tried one with out an O-ring yet... Drop me an email... JDGnut
Mike n Mo
08-01-2005 08:45:23
I use FelPro headgaskets, and have never had a problem. I used to blow a Deere gasket about once a year. Part # is 7744SBX, and should be about $20 thru your local auto parts store. I paint with aluminum paint and put it on wet. Mike
Mike Aylward
08-01-2005 07:35:46
Pullin A, the stock head gaskets will leak on these tractors when the tractor starts to warm up. This was addressed by a Deere Service Bulletin several years ago. The way to make these gaskets hold (even under much higher than stock compression) is to put #3 Permatex (the soft, brush on kind) on the outside vertical rails of the gasket (which is where they always seep). Then, torque the head in 10 ft./lb. increments until you get to 150 ft./lbs. and when the tractor is warm recheck it. Torquing at the small increment is crucial in maintaining an even torque on these gaskets. I have installed several of these this way in late A/60 tractors and have yet to have one leak. Hope this helps. Mike
ChadS
08-01-2005 06:57:30
Where does it keep blowing out at? I made one for an A JD earlier this year, but cant remember which block it was for,,, Nor, do I know if they are the same gasket for all of the blocks,,, If you do use a copper gasket, keep it thick, dont use a thinner than stock gasket on these engines, thicker is better so it will hold in place easier. ChadS
Cotton Picker
08-01-2005 07:54:36
 Re: copper head gasket in reply to ChadS, 08-01-2005 06:57:30
Can you send me info on how your positive traction works on a Super M. Need price also and what it takes to install info.
Thanks,
CP
ChadS
08-01-2005 09:44:54
 Re: copper head gasket in reply to Cotton Picker, 08-01-2005 07:54:36
I sent u an email. ChadS
Mperfection
08-01-2005 19:44:22
 Re: copper head gasket in reply to ChadS, 08-01-2005 09:44:54
hey send my that info too!
ChadS
08-02-2005 10:34:49
 Re: copper head gasket in reply to Mperfection, 08-01-2005 19:44:22
U have mail too! Chad
JDTH
08-01-2005 04:23:17
May want to try a Victor Gasket in the A. Otherwise if you are set on copper, try Lubbock Gaskets @ 806-763-2801.
TheOldMan
08-01-2005 00:30:05
There is a fellow in one of the midwestern states that makes them up custom. I got one for my Super M from him last year. I'll try to look up his info and post it soon.
B ARENIE
08-03-2005 04:10:23
 Re: copper head gasket in reply to TheOldMan, 08-01-2005 00:30:05
WOULD BE INTERESTED IN THE INFO !
TheOldMan
08-06-2005 15:31:52
 Re: copper head gasket in reply to B ARENIE, 08-03-2005 04:10:23
Give me a bit longer as my wife just had surgery and I am mostly busy taking care of her. She is going to be fine but our pulling season may be over.
