what kind of pistons should i use?
super_m
07-31-2005 19:25:09
i am going to rebuild my super m this winter.im gettin the head ported and polished.can i put 4 1/8 pistons in it without boring the block and just use thinner sleeves? what are good but cheap pistons to put in it. what kind of horsepower could i get out of it? also what could i do to the cam?
ChadS
08-01-2005 06:15:07
 Re: what kind of pistons should i use? in reply to super_m, 07-31-2005 19:25:09
third party image
Any questions? ChadS
super_m
08-01-2005 07:00:15
 Re: what kind of pistons should i use? in reply to ChadS, 08-01-2005 06:15:07
do you sell 4 1/8 pistons? how much?
ChadS
08-01-2005 09:44:02
 Re: what kind of pistons should i use? in reply to super_m, 08-01-2005 07:00:15
Yes, we have em. Stock stroke up to 6 inch strokers. They make aound 210 psi of compression. Will work in your SM. 574-893-7437 shop for more information. ChadS
B BARENIE
08-01-2005 03:52:49
I HAVE A SET OF (4) ARIAS PISTONS SET UP FOR A 264 SUPER M BLOCK FOR SALE ! 4.13 BORE, 1" WRIST PIN, 9-1 COMPRESSION RATIO ! IF YOUR RUNNING A STOCK 4" BORE, ORIGINAL SLEEVES MAY BE SAVED FOR A FINISHED BORE OF 4.13. PISTONS ARE SET UP FOR A 5.75 STROKER CRANK ! THE 9-1 RATIO IS BASED ON A 450 GAS HEAD, 180CC IN THE COMBUSTION CHAMBER.
PISTON'S ARE A THREE RING DESIGN, 2 COMPRESSION, 1 OIL RING !
NEVER USED !
BUD BARENIE
ASKING PRICE 500.00 US
colekicker
07-31-2005 20:15:42
Piston and sleeve set. Super M should have a 264 block, so you can step it up to the overbore from 4" to 4 1/8" to make it a 281. These kits are available from many many aftermarket sources such as Hy-Capacity, TISCO and A&I. Polish the exhuast side up like glass on the head and manifold area, change the governor spring drill out the main jet a couple letter bits and you are on your way. Cheap improvements to make some cheap horsepower.
farmallguy
07-31-2005 19:51:31
you could use Super M pistons right on the iron. Seen it done. Works well. 52hp on the pony break at local show.
jd b puller
07-31-2005 19:28:40
This may be a dumb idea, but can you use a SB Chevy 400 piston?
Drew
07-31-2005 19:42:56
 Re: what kind of pistons should i use? in reply to jd b puller, 07-31-2005 19:28:40
The compression height will be too short. The wrist pin on a SBC is .927", I dont know what the IH is, but I know its bigger than that. Another potential problem is the ring pack is high up on the piston and if the motor sees much detonation it can blow the tops off the pistons.
REDWHEELS
08-01-2005 16:41:52
 Re: what kind of pistons should i use? in reply to Drew, 07-31-2005 19:42:56
Has anyone ever used U MM pistons with the 5.75 stroke in a SM-450 block withou sleeves?
LW
08-01-2005 18:16:50
 Re: what kind of pistons should i use? in reply to REDWHEELS, 08-01-2005 16:41:52
They will work and you can stroke it to around 6 1/8 use the M rod and rebush or offset accordinly.
