IH irrigation pump motor...applications?
redcub
07-29-2005 21:32:32
I have been looking around at the local Farmall junk yard and came across a Whitewesting irrigation pump that has an IH motor as the power plant. The Whitewesting plate on the pump says 1971 model. The motor is a 4 cylinder with a big IH stamped in the block at the front lower left (facing the radiator) and the casting number on the block is 534465R1 (the last digit could be an "I"). The distributer comes out on the left side of the block about midway and angles out and up. The missing carb would be on the right side (facing the radiator). It looks to be relatively the outside demensions of an M Farmall motor. Can you tell the cubic inches of the motor from this casting number...HP? Could this bolt up to an M? What else is needed to get information about this mystery?
