john deere A powerblock
virgils
07-29-2005 17:42:23
If you bore out an A powerblock to 6 1/8 can you use pistons for a G.
2 Cylinder
07-30-2005 08:01:00
 Re: john deere A powerblock in reply to virgils, 07-29-2005 17:42:23
I ordered a set of 6 1/8", high compression aluminums from Hinrich"s, they slipped right into place, with some head work and porting it dyno"d 55 HP.
big jugs
07-29-2005 19:39:10
yes, you can. You will have to turn the tops down at an angle for them to slightly slip up into the compression ring. If you buy a set of pistons from Hinrichs or Triple G Service for a bored out power block, these are what you would get. As for heft, these are aluminum. They work absolutely great. If you are stroking it, then you'd better look for something shorter. Good luck!
jd b puller
07-29-2005 18:03:26
I think so, but do you really want those heavy monsters in there?
