Need 30 over pistons for a 5-2 power block
SILVER STREAK
07-28-2005 03:10:32
I need a set of 30 over pistions for a JD B 5-2 power block.
jd b puller
07-28-2005 18:35:20
 Re: Need 30 over pistons for a 5-2 power block in reply to SILVER STREAK, 07-28-2005 03:10:32
I"ve got an extra set of lycoming 5.125 pistons on the shelf. That"s what most guys like in the B powerblocks.
SILVER STREAK
07-29-2005 10:55:02
 Re: Need 30 over pistons for a 5-2 power block in reply to jd b puller, 07-28-2005 18:35:20
How can I contact you about the pistons?
jd b puller
07-29-2005 17:51:23
 Re: Need 30 over pistons for a 5-2 power block in reply to SILVER STREAK, 07-29-2005 10:55:02
You can either Email me or call me at 919-605-6040.
buickanddeere
07-28-2005 11:32:26
Custom built only for 30 thou. How about a thin sleeve in the power block back to stock bore? Worked great in my 5-3 for the 50. Or some monster oversize 250 thou? for the powerblock? They are shelf stocked.
Drew
07-29-2005 15:46:13
 Re: Need 30 over pistons for a 5-2 power block in reply to buickanddeere, 07-28-2005 11:32:26
How thick is the sleeve in your 5-3? How much over did it have to be bored to put the sleeve in? Who has these sleeves? I have a 6-2 that may need sleeved to to work at 6.125.
Thanks!
buickanddeere
07-29-2005 22:50:00
 Re: Need 30 over pistons for a 5-2 power block in reply to Drew, 07-29-2005 15:46:13
I sent the block to the machine shop where the Father-inlaw works. The sleeves were 3/16 thick but had almost 1/8" machined out to obtain the bore size. The sleeve liners were frozen then press fitted into the over bored power-bloc sleeves. Some wonder glop sleeve locker was applied on the bottom half of the sleeves. Some sleeve shop in Texas is about the last place making sleeves long and large enough dia. The 6-1, 6-2 & 6-3 should bore fine to 6.125 for a G piston.
Drew
07-29-2005 23:40:39
 Re: Need 30 over pistons for a 5-2 power block in reply to buickanddeere, 07-29-2005 22:50:00
Key word there, 'SHOULD' bore fine to 6.125". This block was ran without pin keepers and has groves worn into the bore. When I bought this block, only seeing pics and without seeing it in person, I was told that these groves would clean up fine at 6.080, but it is really more like 6.110ish. I have airplane pistons that are slightly smaller than 6.125 (forgot exact dims off the top of my head). In theory, it should clean up, but if the groves are worn off center, then I'm up $#it creek without a paddle. I am already looking ahead and making a 'Plan B' just in case.
buickanddeere
07-30-2005 07:01:54
 Re: Need 30 over pistons for a 5-2 power block in reply to Drew, 07-29-2005 23:40:39
There are some engines out there that run fine with a thou or two deep groove on the cylinder wall.
