5 Star with Cubes
Pulling Prodigy
07-27-2005 23:01:22
how do these 4 cylinder MM 5 Stars pull with the 800HD's in div 4 and 5.....what kinda cubes are they gettion outta them?
Puller
07-28-2005 05:22:54
 Re: 5 Star with Cubes in reply to Pulling Prodigy, 07-27-2005 23:01:22
Going to be like Jim M.
Pulling Prodigy
07-29-2005 09:04:51
 Re: 5 Star with Cubes in reply to Puller, 07-28-2005 05:22:54
no thank you...btw a 5 star is a 4 cylinder anyways
Mopower
07-28-2005 04:51:08
With a stock bore pair of 800 jugs and a std. G 6" crank you will have 533 cubes. Bore them out to the max and run a 7" stroke and you will have about the 660 cube area or with a 7.5 stroke you'll get a bit over 700 cubes. This is assuming you can bore an HD800 to about 5.5". They pull well and horsepower numbers are big with the right heads etc. Torque is amazing. I hope to fit one in my budget someday. My friend builds them regularly. He also makes a 5.75 bore block from a stock U block. You can run water in them and they DO NOT LEAK. Built very well.
