way is a power block better
johndeereb49
07-26-2005 21:41:30
how much better is a power block then a std.
buickanddeere
07-26-2005 22:55:06
 Re: way is a power block better in reply to johndeereb49, 07-26-2005 21:41:30
The Power-Bloc makes more power.
johndeereb49
07-27-2005 02:12:04
 Re: way is a power block better in reply to buickanddeere, 07-26-2005 22:55:06
what is deferent? how does it make more power?
thanks
Mike n Mo
07-27-2005 05:57:24
 Re: way is a power block better in reply to johndeereb49, 07-27-2005 02:12:04
A power block has a bigger bore than the Deere block it replaces. The "B" series has a 5" bore instead of a 4.5" or 4-11/16" (depending on year). The "A" and "60" power block has a 6" bore instead of 5.5". The G power block is 6.5" bore instead of 6.125" Hope this answers your question. Mike
buickanddeere
07-27-2005 08:14:19
 Re: way is a power block better in reply to Mike n Mo, 07-27-2005 05:57:24
Higher compression ratio as well. The higher expansion ratio allows more energy to be extracted from the hot high pressure gasses in the combustion chamber.
johndeereb49
07-27-2005 20:36:36
 Re: way is a power block better in reply to buickanddeere, 07-27-2005 08:14:19
thanks alot that helps.
johndeereb49
07-27-2005 20:43:59
 Re: way is a power block better in reply to johndeereb49, 07-27-2005 20:36:36
how large can you bore a B power block? thanks
buickanddeere
07-28-2005 11:35:03
 Re: way is a power block better in reply to johndeereb49, 07-27-2005 20:43:59
What year, it varies?
johndeereb49
07-28-2005 20:11:24
 Re: way is a power block better in reply to buickanddeere, 07-28-2005 11:35:03
49 b thanks
