Total ignition advance
Mike S
04-10-2001 17:40:40
For a Farmall 350 how much total advance should I have? It's at TDC at low idle and 35 degrees at 1800 rpms. Is 35 degrees to much?
G Taylor
04-11-2001 23:07:33
 Re: total ignition advance in reply to Mike S, 04-10-2001 17:40:40
Best to adjust timing & mixture together on a dyno.One affects the other.A slightly lean mixture burns faster than a rich mixture. Use the least amount of timing without losing significant power.Detonation/knock is death to an engine. Both high rpm HP & lugged down needs to be checked.
