Pulling Tire's for John Deere G.
Miller49G
07-26-2005 19:30:34
I was wanting to know what"s a good size of tire for pulling 6500 to 7500 lb. classes. The mods on the G are as follows .125 over bore, pulling carb, pulling cam, Jerry"s manifold, and cleaned up the ports on the head.
Thanks"
Miller49G
Nothing Runs Like A Deere
07-26-2005 21:45:27
 Re: Pulling Tire's for John Deere G. in reply to Miller49G, 07-26-2005 19:30:34
Id go with a good set of 16.9X38's. or if she really has the pop ive got a set of 18.4x34's that id give ya a good deal on.
Miller49G
07-26-2005 23:58:31
 Re: Pulling Tire's for John Deere G. in reply to Nothing Runs Like A Deere, 07-26-2005 21:45:27
I was going to use the 16.9x38 but wasn"t shore. The tire I was thinking of using was the Firestone, Traction Field and Road R-1 16.9x38 6ply. What size of rim would you mount them on. Can"t buy a 15x38 rim but you can buy a 14x38 rim. Is this a good set up or not 16.9x38 on 14x38 rims.
Thanks"
Miller49G
Jak
07-27-2005 09:58:13
 Re: Pulling Tire's for John Deere G. in reply to Miller49G, 07-26-2005 23:58:31
Your tractor should work well with 16.9's.Thats what I had on my 53 G and it done real well.I had my 12 inch rims widened out to 15 inch wide.I found a guy that has his own metal fabricating shop to roll out a three inch band and cut and weld them in.It costed me some but he did a really good job.See if your local rules allow 16 inch wide wheels and if they do them 16.9's should do you a good job.
