Nervouse about front end coming up
Kevin
07-26-2005 05:18:43
I am going to pull my stock H this weekend but to be honest with you im alittle nervouse becuase it doesnt have wheelie bars. I currently have the hitch/drawbar adjusted up to 19" and im going to drop it down a notch. I have a good feeling it will just about make 4,500 but if i have any room to spare for weights i am going to put them up front.
What are your opinions, it is totaly stock with 12.4 tires on 11 rims. What air pressure should i be running in them? In my case i think i will be better off with alittle more air since its a totaly stock H in the 4500lb class with no wheelie bars. Let me know what you think. Should i go ahead and pull of forget about it untill i get wheelie bars?
Danny Tabor
07-26-2005 12:20:20
 Re: Nervouse about front end coming up in reply to Kevin, 07-26-2005 05:18:43
Kevin, I think you'll be alright. Before pulling check and make sure all the bolts holding the hitch in place are in good shape . Make certain they aren't worn or oblong and if so replace with grade 8's. I have seen an AC stand staight up in the air due to a faulty hitch. Being on the sled there was nothing I could do for him. Thankfully everything ended up okay and right side up. When I was a kid I remember an Oliver 77 twist completely around when one side of his hitch broke away from the tractor. I think checking and double checking any potential weak spots on the tractor is even more important than wheelie bars. When you get to the pull, ask some of the veterans for advise. Tractor pullers are always willing to share their knowledge.
Danny Tabor
AO
07-26-2005 05:58:45
I agree with Mr. Tyler. Don't be concerned with winning first time out! You will have plenty of time for that next week!
Tyler Neff
07-26-2005 05:42:43
Hey Kevin,
Dont worry bout it. If you get nervous just ease up on the throttle and the old girl will come down a little. Your hitch hieght sounds good to me, and as for tire pressure it would just depend on the track. My suggestion to you is go out and have fun. Go get a feel for what its like pulling a sled or dead weight. Dont worry about the specifics just yet. Let this one be a practice run. I think you ll do just fine. Im also very glad to see some new people getting involved in the sport. GOOD LUCK KEVIN and WELCOME ABOARD if ya need to talk call me 937-372-5438 Tyler
