MM Puller
Jeff Blankenshi
07-24-2005 18:12:38
I have a 48 MM UTU. I am wanting to know what is the longest stroke that I can put in it.I know you can put a 6 inch stroke with no problem, but how much bigger can I go. Thanks
Dieselbear
07-25-2005 18:54:53
 Re: MM Puller in reply to Jeff Blankenship, 07-24-2005 18:12:38
I have 7.5 in mine, It took alot of grinding
Jeff Blankenship
07-26-2005 19:57:53
 Re: MM Puller in reply to Dieselbear, 07-25-2005 18:54:53
Want a 7.5 stroke hit the cam. Because mine looks like it would be close with a 6.5 stroke. And grinding, where did you have to grind.
Mopower
07-25-2005 05:47:35
Henderson engine's commonly run 7" and sometimes 7.5. They also hold together exceptionally well. His 5.75 x 7 are hard to beat.
B BARENIE
07-25-2005 04:40:43
MERFIELD HAS AN 8" CRANK SPINNING IN A UB MOLINE IN INDIANA !
ChadS
07-25-2005 10:13:05
 Re: MM Puller in reply to B BARENIE, 07-25-2005 04:40:43
Yep, 15 feet behind the Goodman MM G, and 4 feet behind the Marlatt MMU of Thompsons. But, it does run, just cant hook it up. ChadS
B BARENIE
07-29-2005 21:14:33
 Re: CHAD/CHAD/CHAD in reply to ChadS, 07-25-2005 10:13:05
THEIR JUST YALKING ABOUT CRANK'S !!!!! !
NOT GETTIN ERRRRR RRRRR DONE !
CHILL !
ChadS
07-30-2005 09:29:22
 Re: CHAD/CHAD/CHAD in reply to B BARENIE, 07-29-2005 21:14:33
LOL, OK. Im thinking of building a big Farmall M. Im tired of no body knowing how to properly set up the sled for certain tracks, they would just rather throw on a million pounds of wheel weights and say there ya go! Pull it! They had that sled at goshen weighted down in the 4000lb, and the 4500 lb class, every darn weight was on the sled, and I mean all of em! Reason,,, they did not want to tick off the pullers by doing something different. But hey,, its their backs to throw the weights, BUT its my entry fee they steal when the sled is not set up for the particular class. 280 feet track ,and we get to pull 100 feet in front of 25,000 people! How gallant is that? If they would actually listen to people that has been there, and try,, I mean really try,, they would find out that there is other pullers in the club,, not just the ones they know they have trouble stopping on the sled,, but what about the ones, who never see the box go all the way up the rails for that ever so far away full pull? NOOOO!!!! We like to bend over the lite trctors and weight down the sled and forget bout all us under 4500!!!! See, thats what happens when a heavy weight puller, on the board, sets up the sled, cause it works for him, and he knows it! Im sick of it. I could care less who I tick off by suggesting other options that can actually work, and put on a great show for the crowd, and that will help boost club moral cause they got to go past the damn speed limit cones!!!!! !!! Instead of 20 feet short of the first pylon! Need to git the heads out of Brinkhoff's tail and someone show em that the sled has more potential than just making it heavier. Wish you could have seen it at Hamlet,,, that sled was damn near perfect. And they knew it. ChadS
AC
07-25-2005 18:52:54
 Re: MM Puller in reply to ChadS, 07-25-2005 10:13:05
Thompson put that much work into his MM for 4mph? kind of a waste, maybe a little overkill?
