will I be able to crank it
virgils
07-24-2005 17:49:16
I have a hand start unstyled A. I am thinking about a power block and a 8 1/2 or 9 inch stroke. My question is am I still going to be able to crank it over by hand or am I going to have to convert it to electric start. Or would it be easier to find a older styled tractor already with electric start.
Pullin A
07-26-2005 09:18:06
 Re: will I be able to crank it in reply to virgils, 07-24-2005 17:49:16
What style of reduction starter fits the late A with the starter underneath?
Drew
07-24-2005 18:19:11
If you put petcocks in the power block, and you are a big guy, you may be able to crank it. I believe you will find that hand cranking that size of engine will get old very quickly. The top cover and flywheel from an early styled A will bolt right on an unstyled.
CAPT.HOOK
07-25-2005 13:13:21
 Re: will I be able to crank it in reply to Drew, 07-24-2005 18:19:11
convert!! convert!! convert!! he"s right it will get old quick and save u a lot of time in the long hual good response drew
Robb
07-25-2005 19:50:58
 Re: will I be able to crank it in reply to CAPT.HOOK, 07-25-2005 13:13:21
Convert is right! The factory starter on my G would barely crank a 8.75" stroke! I put a gear reduction starter on and if you convert I would recommend doing that. There is one off of a New Holland loader (I believe that's what it's off of) that is a direct bolt up.
