hey drew
o,kspuller
07-23-2005 20:33:17
do you have pics of you block weth the slevesin it i am thinking of having a block build for 6.500
Drew
07-23-2005 20:55:20
 Re: hey drew in reply to o,kspuller, 07-23-2005 20:33:17
Yes, I can send a few to you. If you are getting a block made, you might as well go as big as possible. If a 6.500 and 6.750 block are both made the same, I would think they would both have the same chance of holding/leaking water. The cost difference between the two would be negligable, but a 6.500 isnt obvious from the outside whereas a 6.750 is.
o,kspuller
07-23-2005 21:06:31
 Re: hey drew in reply to Drew, 07-23-2005 20:55:20
i see, that didnt know they went that big. i have heard of a 7 in , but i am instrested in the bigger block, what block are they using power block or standerd a block my email is [email protected] oh what pistons do you use,
Drew
07-24-2005 16:35:40
 Re: hey drew in reply to o,kspuller, 07-23-2005 21:06:31
I have seen a 7.000" A engine, dont know if its still running or not. I know the 7.000, my 6.750 and another 6.750 that started out as 6"-1 blocks; but I know of another 6.750 that is being made from an unstyled block. The inside of the block is completely gutted and a steel sleeve with a reducer to 5.500 is welded in as an assembely. The bore spacing on 6.750 is spread .500"
If you are serious about putting a big block in, I hope you had 3.000 pins put on the crank. Mine are 2.750 and I trust the guy that made it, but I know deep down its on borrowed time with that big of piston infront of it. The key is to be nice to it and not rag on it too hard. When it breaks I'll back up and punt, then put it back together.
I made my own pistons and rods.
I sent you some pics.
o,kspuller
07-24-2005 21:25:27
 Re: hey drew in reply to Drew, 07-24-2005 16:35:40
how much did the block cost and what did the pistons cost to and what was the pistons pored or block cut out
o,kspuller
07-24-2005 17:22:50
been a big help thank you
