superm head on a 450 with firecraters?
TONY J
07-23-2005 08:45:12
will a super m head 8060 work on a 450 block with firecrater pistons in it...
also would like to know if a 12" super m flywheel will fit in a m....or who makes a high power clutch for a 11" m
thks
tony
B ARENIE
07-25-2005 04:46:36
 Re: superm head on a 450 with firecraters? in reply to TONY J, 07-23-2005 08:45:12
THE ONLY PLACE YOU MIGHT HAVE CONTACT WOULD BE THE DOME AREA !
SET THE HEAD ON WITH NO GASKET !
IF IT HITS, THEN START GRINDING THE DOME'S FOR FIT !
farmall2
07-23-2005 13:10:33
The 8060 head is NOT as good as the 450 gas head. Use different domes and keep the better head. And yes the Super M thru 450 flywheel will work on your old M. Use a Super M clutch disk for correct spline. Ag Parts sells HD clutch and pressure plates for this application available at most tractor dealerships.
TONY J
07-23-2005 14:16:50
 Re: superm head on a 450 with firecraters? in reply to farmall2, 07-23-2005 13:10:33
used my 450 gas head on my puller, just had a 8060 head avail out of my m i bought for the chassis and didnt know if it would work or not.....piston to head clearance is what i was worried about
thks
tony
ChadS
07-24-2005 14:08:25
 Re: superm head on a 450 with firecraters? in reply to TONY J, 07-23-2005 14:16:50
8060 head and firecraters will hit, The later heads SM-450 were made for the firecrater piston design. There is a slant along one side of the compression chamber on the later heads that makes room for the shape of the firecrater. Super M heads the good one is the 8574 castings, same as the 400-450 gas heads, but with the old 4 digit casting codes. 8060 in my book dont belong on super M's Messes up the induction system. ChadS
Chip
07-23-2005 19:38:38
Check clearance with PLAY DOUGH, the kind the kids have, just put little balls of the stuff on top of the piston put the head on with an old gasket then rock the crank back and forth on top dead center, remove head and measure the thickness of the dough.
petetx
07-23-2005 20:09:01
 Re: superm head on a 450 with firecraters? in reply to Chip, 07-23-2005 19:38:38
use lead wire twisted or soft solder on top of pistons roll engine thru mike thickness then you know exact clearence
