Allis WD45 Starving For Fuel ?????
Alicefan
07-19-2005 19:10:27
I have a WD45 that tends to starve for fuel when the front end comes up at the end of the run. I have as much weight as I can add on the front and still be in the 4500 farm stock class. The problem seems to be the gravity feed from the tank to the carburetor. At 12 inches of rise, the fitting on the tank and the carb are level. That is when it starves out. I could get another ten feet if I could keep fuel flowing. I did away with the sediment bowl and gained a little. Any one else had this problem?
