JD 4240 NA farm Stock need hp
IL jd puller
07-18-2005 18:08:51
I was wondering if there were any na tractor pullers that could help me get hp still use the tractor on the farm and will not bore it out because it is a farm stock class we already have the big injection pump so we need more air. would really appreciate your help
darrell b.
07-19-2005 15:40:31
 Re: JD 4240 NA farm Stock need hp in reply to IL jd puller, 07-18-2005 18:08:51
I know a guy that can help you his number is 812-1468 ask for darrell let ring several times i think he"s bush hogging
JD 4010 eat'n IH 1468s
07-19-2005 16:08:23
 Re: JD 4240 NA farm Stock need hp in reply to darrell b., 07-19-2005 15:40:31
okay so darell is a 1468 IH that doesnt get to pull because he is always bush hogging.. how much do you want for it he might be alot cheaper than getting this pooch to run we might use it on the grinder all the time and pull the 4010 instead or just send the 4240 to the fence row
dej(JED)
07-21-2005 06:12:45
 Re: JD 4240 NA farm Stock need hp in reply to JD 4010 eat'n IH 1468s, 07-19-2005 16:08:23
I have a stock, wf, JD 4010 LP that would make you a whale of a stock puller and then you can leave everything as it is. $2600 and it needs only batteries.
