m5 moline
trak560
07-18-2005 05:23:37
does anyone know any tips to get more power out of an m5 moline. not really looking for any internal engine work right know but anything would help. let me know. thanks in advance
Mopower
07-18-2005 11:56:54
 Re: m5 moline in reply to trak560, 07-18-2005 05:23:37
Without working on a bore job or putting a G crankshaft in it, I would say the best thing you can do is put the M670 heads on it. 10A4232/4231/4230 series heads breathe better. Higher compression would help too. Also maybe replace your gas manifold with M670 manifolds (LP gas M5 manifolds are similar if not identical). That is all I can really tell you without going to a 4.81 bore with a G crankshaft and a good cam. Head porting work can do wonders too. Hope this helps! An M670 carb venturi would be bigger than stock and probably work well with those heads.
