Cutting a chrome pipe
JD 4010 puller
07-16-2005 10:14:59
Do you think wraping it in masking tape and cutting with a band saw with coolant would keep the chrome from flakeing? Any input? Thanks
1206puller
07-17-2005 19:16:37
 Re: Cutting a chrome pipe in reply to JD 4010 puller, 07-16-2005 10:14:59
Mine that I bought for a hundred bucks didnt flake or discolor and I used a chop saw to cut it off. I just wrapped it where the pipe came in contact with saw in a rag and cut it off. I went slow as to not leave a burr on the bottom side of the cut.
Good luck.
ChadS
07-16-2005 12:24:15
I used a large pipe cutter, wrapped the area with tape so the rollers dont scratch it up, worked great, straight cut. Hope this helps, ChadS
JD 4010 puller
07-18-2005 19:47:37
 Re: Cutting a chrome pipe in reply to ChadS, 07-16-2005 12:24:15
Thanks for the info
