Jerry's Head Set up
Nothing Runs Li
07-14-2005 18:37:25
Alright so with the head. Who did you guys go for carb set up? Are you also running a fuel pump with it?
Big Jugs
07-14-2005 19:03:17
 Re: Jerry's Head Set up in reply to Nothing Runs Like A Deer, 07-14-2005 18:37:25
Are you running the A head or G head? Scrap the A head and get a heisler. Roberts Carb is about the best or ask some fellow pullers. Someone is bound to know of someone who has spent the time and carefully calculated things out...I know someone who has. As for fuel pump...maybe, if you're trying to feed some god-awful cubes. If you're under 550 or so, probably not.
Nothing Runs Like A Deere
07-14-2005 20:00:16
 Re: Jerry's Head Set up in reply to Big Jugs, 07-14-2005 19:03:17
Its for my G. The cubes are around 800 I think! Its a 7.5 by a 9.25. Fuel Pump!
Big Jugs
07-15-2005 06:47:23
 Re: Jerry's Head Set up in reply to Nothing Runs Like A Deere, 07-14-2005 20:00:16
You're o.k. with the head then. I would run a fuel pump. Doesn't have to be anything outrageous, just to keep a steady supply of fuel to the carb. If you're using stock tank, gravity just doesn't seem to always supply enough. Simple pump-5-7lbs is all you need. It's 817 cubes by the way...
