Stroking and A, and Raising compression
John Deere Pull
07-12-2005 11:54:29
I want to stroke my A but, i dont know how far i could stroke it. A guy where im from stroked his to 9 in. I dont know if its possible but i wanna try. Where can i get the crank and the rods for it. And what is the max compression i can run on my A, and to raise it should i plain the head, or use a diff piston desgin,.
Drew
07-12-2005 16:16:47
 Re: Stroking and A, and Raising compression in reply to John Deere Puller, 07-12-2005 11:54:29
What year is your A? Depending on what year it is, you may have more work cut out for you. 9.500" is about as big as you can go with the cam in the stock location, using a 2.750" bearing (JD D329/303gas). If you dont have a huge bore, you can run the 2.750 pin and it will last a long time provided the crank is made correctly and you dont abuse the engine. If you have a huge bore, a 3.000 pin is a better route for reliability reasons. Look at TNT in Polo, MO for a crank.
I would shoot for somewhere in the mid 9's to the mid 10's in compression. You definately want to get your compression with your rod/piston combination instead of wacking a ton off of the head.
If you are going to the trouble to put some cubic inches in the thing, you need to look at your air cleaner/intake pluming, carburetor, manifold, head, camshaft and rockerarm situation to make it all work together.
John deere puller
07-12-2005 20:51:31
 Re: Stroking and A, and Raising compression in reply to Drew, 07-12-2005 16:16:47
I have a 50 A and a 38 A, And How far can u bore the A's.I got the carb and ignition set up through denny's carb shop.
