tired oliver
DJE
07-11-2005 19:52:17
I have a 41 oliver 70. I pull 4000 - 4500lbs going to overhall the engine and was woundering for any performance help Im limited to 1800 rpm.
Bryce
07-12-2005 06:53:17
 Re: tired oliver in reply to DJE, 07-11-2005 19:52:17
I built one to 325 ci,runs good but if I had it to do over,I'd restore it and build a 77.You get alot more out of them for the money.However if you want to stick with the continental run a hiesler manifold get the older (bigger) zenith carb,take .125 off the head,just remember to shim the rocker arms back up and you will have to make the holes in the side cover bigger to bolt back up to the head.I don't know how far you want to go with it but if you have any questions I'll let you know what I can. As far as bore and stroke,all it takes is $$$$ and work.
James Tierney
07-17-2005 18:31:06
 Re: tired oliver in reply to Bryce, 07-12-2005 06:53:17
Are the Hiesler heads for Oliver 70's still available? Do they appear similar to stock?
Thanks
