Angle cut rods
Jerry B
07-11-2005 13:34:48
I am needing some info about some connecting rods.
I am looking for a rod that has the rod cap set on at a 45* angle rather than the standard 90* angle. I know Oliver used them in the 310 but I need one with a crank pin diameter of less than 2.00 inches.
Someone suggested the rods used in a Ford Courier pick up truck with the Mazda engine. The crank pin on it is only 1.79 or so. I feel this might be a little too small for a 6 inch stroke crank.
Your thoughts gentlemen?
LW
07-11-2005 16:16:54
 Re: Angle cut rods in reply to Jerry B, 07-11-2005 13:34:48
Continental has a 2.06 approx. rod journal with canted cap. Deck height could me an issue? Is this a Oliver engine? these rods work but they are not strong enough to live at higher power levels.
JerryB
07-12-2005 10:22:40
 Re: Angle cut rods in reply to LW, 07-11-2005 16:16:54
Yes, rod strength has been an issue ever since I started the project.
I have a set of Cunningham rods but they are too thick on the big end. I had them machined by Gingrich (sp?) to reduce the thickness and they kept my original bolts and substituted an unknown bolt of unknown quality.
