Tractor pulls Jackson MN
JDBert
07-11-2005 08:27:03
Antique tractor pull Jackson MN Sunday July 17th, noon start.
3500-11500 stock, 4500-7500 open.
And another during the county fair on august 6th,noon start.
For more info contact the Chamber of Commerce at 507-847-3867
ReedA
07-11-2005 12:50:11
 Re: Tractor pulls Jackson MN in reply to JDBert, 07-11-2005 08:27:03
What are the rules in the stock class? No cuts in stock? Tire size?
If you have rules please e-mail to [email protected] Thanks
JDBert
07-11-2005 13:39:04
 Re: Tractor pulls Jackson MN in reply to ReedA, 07-11-2005 12:50:11
Stock class is prior to or in production in 59'. Tire size limits depending on class up to 7500 then any size is ok. 3.5 mph no shifting no TA use. original rim and wheel set up (ie no pressed steel on a JD "G") No cut tires. Weight brackets are no further then 11' from center of rear axe. Engine, stock block, no blowers or turbos except factory (99 ollie, 435 JD). Stock heads manifold and carbs, air cleaners can be modded. 10% over stock RPM's. 20" high hitch not less then 24" from center of rear axe for a 3" clevis, loops are 27" from center of rear axe. PTO must be operational.
