To; A-man
cowboy from Kan
07-09-2005 20:29:03
If it was a good pulling tractor then answer this. Why when I took the tractor for a short spin then why did it have a knocking in the motor. and this was the same day that he brought it home. Because he called me and asked me to come take a look at his new puller. Also when I drove it around the block the flywheel wobbled and shook so bad that I thought that it was gonna explode underneath me. This was also about a month or maybe less before he even took it to the first pull using this tractor. Also please tell me why there was always a miss in the motor everytime after the tractor was started and got warmed up, as well as the constant oil leaks around the flywheel that left puddles on the garage floor. I think that this tractor was about half of what you said it was. I can tell you from knowledge that the 46 A was more than 3 times the tractor that you traded for it
K-CHEVY
07-09-2005 21:44:27
 Re: To; A-man in reply to cowboy from Kansas, 07-09-2005 20:29:03
I know it was 3 times the tractor , more than the 36 i also know i went to the pulls just too watch the 47 pull
Drew
07-11-2005 18:40:34
 Re: To; A-man in reply to K-CHEVY, 07-09-2005 21:44:27
How is a tractor with just a power block and the humongo Jerry's head 3x a tractor with a big crank?????
