Farmall propane heads
Jackofalltrades
07-07-2005 19:49:10
Hi! Can anybody tell me if you can put 450 propane head on a dome piston motor? Is there enough clearance? Or do they need to be flat top pistons? Any other suggestions on getting more power would be appreciated. Thanks
cotton picker
07-08-2005 07:30:58
 Re: Farmall propane heads in reply to Jackofalltrades, 07-07-2005 19:49:10
I tried it with the IH firecrater pistons, made two pulls before #3 had the valve break because the piston was hitting it(We thought I had a bad lifter from the clicking noise). Installed a set of M&W add power pistons and havent had a problem since. Also, you could have your firecrater pistons milled down to make room.
ChadS
07-08-2005 07:02:25
My cousin has a M with a LP head and M&W pistons, they have a pretty tall dome on em. we set the head on without a gasket and turn the engine over, it cleared just fine. Some you have to be careful with, it wont hit the valves, or the top of the chamber, but will hit the along the sides of the chamber. Chad
supermpuller
07-07-2005 19:56:21
I ran a SM with 281 ci. LP intake ,exhaust LP head , 450 cam, 4.125 firecrater pistons, no problems. new set-up now pistons are for sale
REDEYE
07-08-2005 05:28:38
 Re: Farmall propane heads in reply to supermpuller, 07-07-2005 19:56:21
what are you asking for the pistons, 1" or 1.312" pin? email is open
supermpuller
07-08-2005 07:03:18
 Re: Farmall propane heads in reply to REDEYE, 07-08-2005 05:28:38
The pistons came out of a SM, I'll have to check pin size.
ChadS
07-08-2005 07:45:52
 Re: Farmall propane heads in reply to supermpuller, 07-08-2005 07:03:18
SMP, email me, need to talk to you please. Thanks, Chad
