greenville ohio pull
somepuller
07-06-2005 15:07:23
Is there a cut tire pull there this weekend or just a div 2 pull. Need some directions to pull
thanks
sos puller
07-07-2005 03:37:11
 Re: greenville ohio pull in reply to somepuller, 07-06-2005 15:07:23
there is a pull at the park outside of town the same day running div 2-3 top cuts in div2 full in div 3. this is not the pull at the fair grounds. i think it starts at 2 fast time. div2 is 58 and older. 16.9x34 allowed above 5000lb. they have a park there where they have steam and tractor shows. div3 18.4x38 cuts max.
RON D.
07-07-2005 05:12:29
 Re: greenville ohio pull in reply to sos puller, 07-07-2005 03:37:11
What MENCHHOFER is trying to run other pulling events numbers down so he can run his sled and rules everywhere.
sos puller
07-07-2005 07:13:01
 Re: greenville ohio pull in reply to RON D., 07-07-2005 05:12:29
nope this pull was set up last year. and i am not menchhofer anyway, but i do run with with him and they are not his rules, they are our clubs rules. and we have a sled to rent to anyone and they can use any rule combination they choose it is there show our sled.
somepuller
07-07-2005 17:36:56
 Re: greenville ohio pull in reply to sos puller , 07-07-2005 07:13:01
What year is it for div 3 58 or 59? Where is this park
mark /sos
07-07-2005 18:56:11
 Re: greenville ohio pull in reply to somepuller, 07-07-2005 17:36:56
most is 57 i'm not sure what they allow.
earlschieb
07-06-2005 19:42:59
Here is the link for this pull.
Stateline Puller
07-06-2005 18:08:48
IN THE FARMWORLD IT SAYS DIV 1 AND DIV 2 AND 8500 FARM STOCK
Farmall M Puller
07-06-2005 16:21:47
thay are having div. 1,2,3 and farm stock on sat. the 9th. Check the rules on central ohio's website for div 3 but I think they run cut tires.
Where are you coming from and I will also help you get here.
Link
http://www.dctpa.com/ Darke county
Farmall M Puller
07-06-2005 16:25:34
 Re: greenville ohio pull in reply to Farmall M Puller, 07-06-2005 16:21:47
TIRES
No radial tires, steel wheels, duels. Two-wheel drive only. Any cut allowed on tires. Manufactured data must be intact. Tire size will be 15.5x38 or 14.9x38. Maximum footprint per Firestone tire chart D170, 200 sq. in. Any rim width
