pull in pennington gap va
swta puller
06-29-2005 12:37:25
pull in pennington gap va sat july 2 at 4 pm weight in starts at 3 there will be fireworks in the park at 10 pm also pull is at leeman feild
swatpuller
06-30-2005 18:51:16
 Re: pull in pennington gap va in reply to swta puller, 06-29-2005 12:37:25
At Duffield turn left on 58-421. Go across two mountains turn right onto 421 at Dot. Go to the first red light and turn left, then next light make a right. Leeman Field is about 3/4 mile on the right.
Our hitch hiegth is 20inches, 18 inches from the center of the axle, hangon and wheel weights are allowed. We pull two classes farm stock and classic. Farm is required to have a working PTO and pull off of a clevis, classic has a 4mph speed limit. Hook fee is 10.00 for nonmembers and 5.00 for members. Membership is 25.00 per year. Hope to see you there.
redcub
06-30-2005 19:35:20
 Re: pull in pennington gap va in reply to swatpuller, 06-30-2005 18:51:16
Can farmstock have weight brackets and suitcase weights? Are you pulling light up? Thanks again
swat puller
07-01-2005 11:53:48
 Re: pull in pennington gap va in reply to redcub, 06-30-2005 19:35:20
yes you can use suit case weights we are pulling heven down the week start a 7500 lbs classic 7000 farm
6500 classic
6000 f
5500 c
5000 f
4850 c
4500 f
4350 c
4000 f
3850 c
3500 f
3350 c
3000 f if there is enough to sing up we have a 8000 farm stock class
redcub
06-30-2005 16:40:50
What are the classes? What are the rules on drawbar and weights? Comming from Kingsport, would you turn left on 58/421? Is there a contact phone number you can give? Thank you.
swatpuller
07-03-2005 11:11:12
 Re: pull in pennington gap va in reply to redcub, 06-30-2005 16:40:50
had a good pull last night lost count of how many hooks Had 31 kid in the kidie pull each got a trophy. (most have ever had at one pull)
took a brake from pulling at 10 pm to watch the firework put on by the town of pennington gap
redcub
07-03-2005 13:04:36
 Re: pull in pennington gap va in reply to swatpuller, 07-03-2005 11:11:12
Truck had problems sat. and I didn't think I should try the mountain with it...may be we will catch you next time if we don't have a local pull. thanks for the info.
