how much does super m weigh?
super_m
06-29-2005 10:49:02
im getting my sup.m ready to pull. i have never weighed it so i dont know how much it weighs. i have removed the whole belt pulley system and the gear that runs it.i also took the belly hydraulic pump out of it. it has 14.9X 38's on it with no fluid,no wheel weights.anybody have a idea of how much it weighs? thanks in advance
pulling
06-29-2005 18:55:55
 Re: how much does super m weigh? in reply to super_m, 06-29-2005 10:49:02
My Super M with everything the same as yours except I have the belly pump in weighs 5170 on the scales at the pulls. I guess the belly pump removes another 120 lbs.
ChadS
06-29-2005 11:07:20
somewhere in the range of 5100-5250 with cast wheels. with pressed steel, have seen them down as low as 4700 with nothing chopped up. Chad
Mperfection
06-30-2005 18:31:10
 Re: how much does super m weigh? in reply to ChadS, 06-29-2005 11:07:20
I built my own tube front end with 15" tires and got mine down to 4300 dont kill yourself though because they dont pull worth crap that low. I put on wheel weights to put at 5000lbs does good there. Good luck and have fun!
