Posting General Rules (MI)
Clintonia Antiq
06-28-2005 06:04:34
Welcome fellow tractor pullers to the Clintonia Club. We pull in the general Lansing, MI area. We pride ourselves in having a class for everyone. I would like to thank all pullers that came from near and far to have some fun at our BIG little club. Farm Stock classes are listed seperately. Here are the amended Antique/Classic/Fun rules to the best of my knowledge:
Clintonia Antique Farm Power Club
General Pulling Rules
1. Tractor and engine must be of brand name, manufactured in 1957 or before, and have the serial number in its proper location. There can be no alterations that change the appearance from its original specifications. Every tractor must have fenders.
2. Weight classes are as follows: 2500, 3500, 4500, 5500, 6500 lbs. (+/- 1%). A 7500-weight class may be added depending on the event. No fuel can be added after weighing in. Tractors are divided by year of manufacture. 1945 and prior are designated �Antique�. Machines manufactured in 1946 and after are considered �Classic�. Fun Class and Farm Stock Class are not divided by year. (Farm Stock Class rules are listed separately.)
3. Each tractor will have a minimum of one pull per class per event, or two pulls per round when using a stone boat. Tractor may jump weight classes but not jump from Antique to Classic or vice versa. Tractors will receive no more than one trophy per class with only the first driver being eligible for a trophy.
4. A tractor must not have any added governor controls such as strings, wires, or foot controls. Use of factory installed governor controls (example: John Deere H) cannot be used. Engine RPM is to be no more than 10% over factory specifications. Pulling speed is controlled by a speed limit horn. You are allowed two warning beeps. A driver is disqualified upon the third beep of the horn or one beep longer than three seconds. Antique/Classic Class is set at 3.0 mph, while Fun Class is set at 4.5 mph.
5. There should be no alterations from original manufacture except at the point of clevis to obtain a maximum height of 19 inches at the point of hitch. The hitching point must extend beyond the outside radius of the rear tire. Clevises are to be rigid, have a minimum 3-inch opening, and be flat or twisted. No vertical clevises are allowed.
6. The driver must remain seated and physically signal tractor is out of gear when hitching and unhitching from the sled. The driver must remain firmly seated and keep one hand on the wheel at all times while pulling while obeying the track flagman�s signals. The chain must be tight and track flagman signal �go� before proceeding to pull the sled.
7. No weights shall extend beyond eleven feet from the center of the rear axle. No added weight behind the hitch point will be allowed. All weights must be safely secured to the tractor. Any objects falling of a tractor while hooked results in disqualification.
8. A maximum tire width of 18.4 inches will be allowed with 33-inch rims or less. A maximum of 15.5 inches will be allowed for rims over 33 inches. If tires are other than what the rules specify, burden of proof of stock tire size is on the puller. One size over factory stock tire width is allowed. No rice tires or radial tires shall be used. The front of traction bars cannot be altered. There are no restrictions on the top of the bars.
9. Maximum rim width is as follows: 10 inches (2500), 11 inches (3500), 12 inches (4500), and 14 inches (5500 & 6500). Dual wheels are not allowed. Tractors must be two-wheel drive.
10. Minimum age of a driver is 14 years old. Written consent of a guardian is required if a driver is under 18 years of age. Proof of age is required unless superseded by fairground rules.
11. Pull will be based on the distance pulled. When pulling a stone boat: If the sled is at one end of the track and the puller is unsuccessful in moving the boat on his first attempt, the operator may request the sled be moved to the center of the track.
12. Out of bounds lines will be clearly marked. If a tractor touches the line, the driver is disqualified.
13. Judges will determine if a tractor�s front end is rising above a safe point. Wheelie bars are recommended.
14. No alcoholic beverages are to be consumed by participants before, during, or after the pull.
15. Violations of any rules or unsportsmanlike activity shall be cause for disqualification of a participant. Entry fees will not be refunded upon disqualification.
16. All pulls shall have three judges whose majority decision will be final. A club member will be head judge.
17. Any of the above rules may be waived as per interpretation by the judges.
18. It is suggested that each tractor carry an approved fire extinguished class ABC.
19. CLINTONIA ANTIQUE FARM POWER CLUB WILL NOT BE RESPONSIBLE FOR ANY DAMAGES TO A TRACTOR OR DRIVER, SPECTATORS, OR ANY EQUIPMENT WHILE PARTICIPATING IN THE PULLING CONTEST.
Dale in Ar.
06-28-2005 11:56:57
 Re: Posting General Rules (MI) in reply to Clintonia Antique Pullers, 06-28-2005 06:04:34
On ruling number one,you all have "Every tractor must have fenders".I have got to ask,Why? Not every tractor came with fenders and those that did,got taken off years ago by the old farmer who got tired of beating them up with the implements and getting in the way.This rule will rule out many of the old boys that pull for fun and don't want to put alot of money in a activity that will cost them extra. Yes,fenders are nice but they are for the purist in restoring and they don't usually pull their trailer queens.I don't mean anything by the question,just being nosey.
Mopower
06-28-2005 12:12:44
 Re: Posting General Rules (MI) in reply to Dale in Ar., 06-28-2005 11:56:57
I agree with you wholeheartedly, but unfortunately there are a number of rules that exist for liability and insurance reasons only. That would be one of them. I think three or four of mine were available without fenders. Notice it didn't specify what kind of fenders. You might enjoy seeing some of the make-shift ones!
Ken(MI)
06-28-2005 09:31:59
So are the rim rules being enforced or ignored? I don't want to haul my WD to Westphalia, just to be DQ'ed because of 12" rims. I really don't care one way or the other, but it would be nice to know in advance. Ken
LRN
06-28-2005 10:46:00
 Re: Posting General Rules (MI) in reply to Ken(MI), 06-28-2005 09:31:59
Hi Ken, We will allow the wider rims to pull this year and will draft a new rim rule to go into effect for next year. There are some deficiencies in the present rule that is not fair for the smaller tractors. Hope to see you in Westphalia.
Thanks, LRN
Ken(MI)
06-28-2005 17:34:10
 Re: Posting General Rules (MI) in reply to LRN, 06-28-2005 10:46:00
Thanks for the clarification Leeroy, I just wanted to make sure, or I'd bring a different tractor for Krista to pull. See you there.
Ken
