help with clutch and flywheel
minnie ub
06-27-2005 20:11:49
crank case has crank in it with flywheel and clutch on it and it turns free. rear end turn free when out of gear. slide the two together with all the bolts in and she locks up. whats our problem.
family tradition
06-29-2005 12:37:53
 Re: help with clutch and flywheel in reply to minnie ub, 06-27-2005 20:11:49
are you putting any bolts in where people normally hang a belly bracket. if you are the bolts may be too long and hitting the flywheel.
minnieub
06-29-2005 14:42:24
 Re: help with clutch and flywheel in reply to family tradition, 06-29-2005 12:37:53
no i'm using orginal bolts. there is a spiral groove in the pilot bearing that we think is holding it from going all the way back. is that spiral groove suppose to be there. and if not what could have put it there
