Farmall H belly pump removal
JHB
06-27-2005 04:48:07
In order to keep a Farmall H stock without looking stripped, what do you do to keep the original look when you remove the hydraulic belly pump on a H to reduce the original weight to make a class? Does the Super H with live hydraulics have a cover plate?
Flogger
06-28-2005 14:19:49
 Re: Farmall H belly pump removal in reply to JHB, 06-27-2005 04:48:07
Actually the belly pump was an option so you can remove it and still be stock appearing. There was a cast iron plate to cover the opening but I'm sure you can get by with a lighter tin one.
