M Rings
FarmallMMAN
02-21-2002 18:29:02
I was wondering if there would be any advantage or disadvantage to using diesel rings in a gas engine? Would the higher compression help or hender HP?
rings
02-22-2002 06:05:31
 Re: M Rings in reply to FarmallMMAN, 02-21-2002 18:29:02
My non-formal answer is there would only be a minor difference in HP, cause by the increased ring tension. The greater compression of the Diesel is a result of compression ratio, the ring merely have to be able to hold it.
