Hey Chad S/Carburetor
White Wheels M'
06-22-2005 11:13:44
hey chad a couple a weeks ago, you had a post about a H or M that was running ruff, and you finally removed the carburetor, and found that a hole was drilled in the throttle plate, I need to talk to you, what is your telephone number thanks
ChadS
06-22-2005 14:48:08
 Re: Hey Chad S/Carburetor in reply to White Wheels M' Farmall, 06-22-2005 11:13:44
It was a 300. The idle circuit was messed up from day one on it, and at one time, the owner had done that to help with the plug fouling,,, when I plugged it off, it got worse, took a good carb off an M, and it runs good. 574-893-7437 shop phone, Ill be there in the morning round 10 to call. ChadS
