next jd puller project
virgils
06-19-2005 18:34:10
I am thinking about my next puller project. I am thinking on a jd A. I was thinking on buying one of Jerrys 6 1/2 bore blocks. How many more horsepower will this block run compared to just going .125 over on the stock block. I am going to stroke the crank not sure on how much yet. How long of a stroke can you go until you have to start cutting and grinding. Thanks for any info.
LWD
06-20-2005 00:51:18
 Re: next jd puller project in reply to virgils, 06-19-2005 18:34:10
my A has a 6-1/8 bore and 8-3/4 stroke = 77 hp
Drew
06-19-2005 19:36:42
If you dont want to cut and grind any, I think you can take a 6.500 block off your list. I dont know how think the bores are at the back of a Jerry's block, but on a 6.750 bore block with thin sleeves it requires quite a bit of cutting to get it fit.
It depends on what rods you use how much you can stroke it before grinding. 7.500 to 8.000" may swing without too much trouble, but again, what type of rod you use will determine this.
The horsepower gain will depend on what head, camshaft, carburetor, etc you use.
