propane Head for farmall
Jackofalltrades
06-19-2005 18:22:20
Hi! I got a head off a 450 LP tractor. What should be done to it before putting it on a stroker motor? How much help will it be? Hp wise. Should it be shaved? Also have propane manifold. Any help would be appreciated. Thanks
halfbreed m
06-20-2005 20:10:01
 Re: propane Head for farmall in reply to Jackofalltrades, 06-19-2005 18:22:20
i think we should just put it on my m
TONY J
06-19-2005 22:05:29
if you ever decide to sell it ill but it....as far as the milling goes, but matters the piston you have(comp. height) and how much stroke....your cam will also affect the compression ratio, i think the manifold has alittle bigger runners, but not sure on that one.....
