JD G ADVISE
Fredrickson
06-18-2005 20:06:02
I am building a stroker G. I have previously used a stock distributer with electronic ignition on a small cube G. Do I need a 70lp distrubuter for my new motor or will my old one do? Also a while back there was some guys talking about how to relieve the eye brow on a styled G head to help flow the intake valve. Can anyone help me. Thank you.
distributor
06-18-2005 23:21:40
 Re: JD G ADVISE in reply to Fredrickson, 06-18-2005 20:06:02
Your old distributor will work fine. The advantage to the LP is that it doesn't fire every time the piston comes up, only on the compression stroke. I've heard it frees up 5 hp or so but who knows.
buickanddeere
06-19-2005 00:39:26
 Re: JD G ADVISE in reply to distributor, 06-18-2005 23:21:40
Makes no difference and save your $$$. A new bushing in the dist is a good idea. No gasket and just a thin bead of gasket goop on the timing cover helps reduce timing scatter from worn gears.
