cokshutt 40 motor
jim brunk
06-18-2005 19:00:02
Does anyone know what allis combine motor fits in a cockshutt 40, and how much more power it has
262
06-18-2005 23:24:54
 Re: cokshutt 40 motor in reply to jim brunk, 06-18-2005 19:00:02
D-19 motor fits. It was also used in a Gleaner combine. It's 262 cubic inches and from the factory had about 72 horsepower. You'll have to alter or take off your fan shroud to make it work, make a front mounting bracket, and put the back plate/clutch/flywheel from your 40 motor on it to make it work. You can just take the 262 crank and it will bolt right into the 40 motor and give you 1/4" more stroke about about 75 horsepower with a big enough carb. You'll have to either knotch the stock cam or put the 262 cam in though so it will clear.
