Oliver88
Farmpuller
02-20-2002 14:53:56
I have found an oliver 88 1950 or 51 ? Want to know if I can pull in farm class with pressed wheels instead of cast. I was told that 88 oliver did not come from factory w/pressed steel. Any info would help. Thanks
laipuller45
02-20-2002 17:20:07
 Re: oliver88 in reply to Farmpuller, 02-20-2002 14:53:56
most places will let you get by with it, around central ky, that is the way it is anyway. just can't run anything larger than a 16.9 below 6500 lbs. look for a local pulling club and see if you can find out anything about their rules. i would say go ahead and run then sometimes it is easier to ask forgiveness than it is for permission. hehe
tom
02-20-2002 18:19:19
 Re: Re: oliver88 in reply to laipuller45, 02-20-2002 17:20:07
Oliver model 88 tractors came from the factory with pressed steel wheels, so don't worry about it your not breaking any rules.
