Shelbyville, TN pull
JDGKid
06-15-2005 10:23:46
When is the next Shelbyville pull? The sheet says July 4th but that is a Monday. Is it the 2nd or what? Also is the July pull a points pull. I need to know if the fair pull is a points pull also. I hope you can help because if one is not a points pull we are going to bring a different one than usual. Thanks.
Bamapuller
06-15-2005 16:31:01
 Re: Shelbyville, TN pull in reply to JDGKid, 06-15-2005 10:23:46
The next Shelbyville pull is on Monday July 4th starting at 11am. Will be pulling all the usual classes. Supposed to pull awhile, then have a cookout, and then finish the pull. Flyers say that all this years pulls are points pulls. I believe the fair pull on July 30th is NOT a points pull, will have to ask about it on the 4th.
JDGKid (Houston Jackson)
06-15-2005 18:20:16
 Re: Shelbyville, TN pull in reply to Bamapuller, 06-15-2005 16:31:01
Thanks for the info. Are you Crane Collier? Let me know.
Bamapuller
06-15-2005 19:19:23
 Re: Shelbyville, TN pull in reply to JDGKid (Houston Jackson), 06-15-2005 18:20:16
Yes, I am. How's it going JDGKid?
JDSixty
06-15-2005 18:49:50
During the last pull at the puller meeting it was said that this would not be a point pull on july 4th.
Bamapuller
06-15-2005 19:21:34
 Re: Shelbyville, TN pull in reply to JDSixty, 06-15-2005 18:49:50
I didn't know that. Had a flat on the trailer and missed the drivers meeting.
JDGKid
06-15-2005 21:11:23
 Re: Shelbyville, TN pull in reply to Bamapuller, 06-15-2005 19:21:34
Thanks for the info Bamapuler and JDSixty. Are you sure that the 4th is NOT a points pull? Oh, Bamapuller thanks for the numbers for the fuel in Shelbyville Hank called her and it is alot cheaper than the fuel he has been buying. See ya'll on the fourth.
B Mitchell
06-16-2005 23:24:46
 Re: Shelbyville, TN pull in reply to JDGKid , 06-15-2005 21:11:23
The July 4th pull will not be a points pull and they are not giving out trophies will be money instead. Also the Fair is a points pull.
