MW 9 Speed overdrive in Farmall H - need help
jim bradley
06-14-2005 19:18:40
Been working on my tractor. It was a stuck tractor. Got it running real good. It has slipped into neutral on the overdrive. Only have road gear. Can anyone help me. What do I do to adjust or get the tractor back in the low side? Anyone had any experience with the cable shifting type of overdrive. Pull to put it in overdrive. Push to put it back in straight gears. I have pushed all there is to push and it still stays in neutral on 1 - 4 and reverse. Low becomes faster than straight 4th when it is working right. Does not effect road gear. I think I am right that it is a M&W. Please give me some advice.
Jeff Oliver
06-15-2005 05:04:13
 Re: MW 9 Speed overdrive in Farmall H - need help in reply to jim bradley, 06-14-2005 19:18:40
Yep sounds like a M&W. We have one on a M but have never had a problem with it. It sounds like something has broke or shifted in the tranny and will not let it shift. Might have to take the top off and look as I have never been into on but it shouldn't be too bad to find.
