15.5x38 on 12 inch rim
super_m
06-12-2005 14:36:51
will it work? if it will how well?
colekicker
06-12-2005 16:26:14
 Re: 15.5x38 on 12 inch rim in reply to super_m, 06-12-2005 14:36:51
I sure like mine on a 14" rim. It really gets the sidewalls square. I am running Safemark tires, so it may depend on what brand you are running.
dctom
06-12-2005 14:42:11
IMHOP better than on a 16" rim, running my 14.9x38 on 11 " rim doing very good
CLARENCE BARENIE
06-13-2005 04:22:53
 Re: 15.5x38 on 12 inch rim in reply to dctom, 06-12-2005 14:42:11
ONE OF THE WELL KEPT SECRETS, RUNNING A TIRE ON A SMALL WIDTH RIM THAN WHAT THE MFG CALLED FOR.
WHEN YOU DROP IN WIDTH, THIS GIVES THE TIRE MORE CONTACT PRESSURE IN THE CENTER, MOST IMPORTANT WITH A NON-CUT TIRE, 11" MIGHT NOT BE PERFECT, TIRE PROBABLY CALL'S FOR 14". BETWEEN 12-13" WOULD PROBABLY BE IDEAL !
