JD B weight
Glen E.
06-08-2005 10:42:29
Anyone have an idea what a styled B will weigh. '50 model, pressed steel wheels, not a rollamatic front, fairly stock everything, does have a power trol but not arms on it. Hoping to get it a 3600 pound class, Driver ways about 200.Thanks.
phil2
06-11-2005 13:04:00
 Re: JD B weight in reply to Glen E., 06-08-2005 10:42:29
My 50 B, with Rollamatic, me aboard (170) is 4460 pounds.
jd b puller
06-08-2005 15:05:43
It"ll be tight. Mine is a 47 and has the flat cover on the back, 13.6-38 Riverside tires and weighs about 3200# with no driver. I have to pull all the weight brackets off in the 3500 except the front one to get enough weight on the front (still isn"t enuff). WHere are you located at?
Steve Van Drimmelen
06-08-2005 16:43:49
 Re: JD B weight in reply to jd b puller, 06-08-2005 15:05:43
Your 1950 'B' is often refered to as a "late styled B" and will weigh close to 4,000 lbs. In 1947 there was a significant style change, the axles were squared, the pan seat was replaced by a square one with a back support and the battery was moved from under the hood to under the seat. The engine was also enlarged from 175 cubic inches to 190. Like JD 'B' Puller I also have a 47 "B" that we pull in 3,500 and 4,000. It has the flat back and pressed steel wheels to get that low but it has the pan seat, round axles and a high & low axle transmission...hope this helps.
Steve
