KN Filters
Nothing Runs Li
06-07-2005 10:29:55
Good, bad? With a G, how do guys mount them. Thanks.
G/MAN
06-09-2005 15:46:10
 Re: KN Filters in reply to Nothing Runs Like A Deere, 06-07-2005 10:29:55
I've heard that the K&N filters aren't good for any power gain on Deere two-bangers. Granted they flow better than an oil-bath cleaner, but you have a lot smaller volume of "intake system" ahead of the carburetor when running one. Since those two-cylinders take two BIG gulps of air in rapid succession, it's possible that even with the good-flowing filter media, there's not enough volume there to produce more power. But with the stock oil-bath, you have a much bigger filter cannister and more intake piping. Or maybe they K&Ns flow too much air, and reduce the velocity of the airflow into the carburetor. It would be interesting to plumb each type of set-up with a vacuum gauge and see what happens under heavy load. I would say that the biggest benefit by far in using a K&N would be the weight savings, as those stock oil-bath intake set-ups are pretty heavy. Removing the whole works probably takes off at least 40 lbs, maybe more.
GPULLER
06-10-2005 08:02:08
 Re: KN Filters in reply to G/MAN, 06-09-2005 15:46:10
I noticed that when the tractor was under load, the sides of the K&N were actualy sucking in. I believe that maybe there isn't enough media area for the volume of air. I was told that reason it was collapsing was the filter was over oiled.
G/MAN
06-10-2005 10:02:11
 Re: KN Filters in reply to GPULLER, 06-10-2005 08:02:08
No, if you can see it physically sucking in, it's not capable of admitting enough air all at once. Two-lungers have their intake strokes 180 crank degrees apart. On a stock "G", that means the intake system must be able to supply enough air to fill 413 cubic inches of engine (at least in theory - the actual VE isn't that high) within the fraction of a second it takes the crankshaft to rotate through both complete intake cycles. As I said, the factory intake system has a much larger volume available.
GPULLER
06-08-2005 08:04:56
I installed a K&N on my G that was a cone shaped, 8" on the big end and 4" on the small end. I mounted it on the end of the carb with exhaust tubing elbow the same diameter as the carb inlet and faced the filter down. I dynoed the tractor with the K&N, and with the carb hooked up to the oil bath. No power gains with the K&N. I have been told that they do work better if mounted to the original carb elbow. I have never tested that theory. The filter now hangs on the wall in my shed.
jd b puller
06-08-2005 18:46:54
 Re: KN Filters in reply to GPULLER, 06-08-2005 08:04:56
GPULLER, how many cubes is your G? That could have something to do with it. Did you make any changes from K&N to oil bath?
GPULLER
06-09-2005 13:23:45
 Re: KN Filters in reply to jd b puller, 06-08-2005 18:46:54
My G is just .090 over stock stroke. All dyno testing was done on the same day. No other changes to the motor.
snafu
06-07-2005 17:25:47
Make sure it stays out of the air turbulence off the fan, found out that upsets the air flow thru the carb.
intake
06-07-2005 11:26:28
on mine where the intake went up into the breather from the carb, I just turned the pipe down and slide a K&N I ordered from Jegs over it. Fits perfect and works good.
06-07-2005 15:13:07
 Re: KN Filters in reply to intake, 06-07-2005 11:26:28
Thats what I was thinking. Actually I was even thnking about turning it outside the tractor. I just want to make sure and find the clodest air possible.
