Gas Octane Necessary
jhb
06-04-2005 02:09:55
I just rebuilt a gas Farmall engine. After a few hours of operation I ran a compression check. It had 165 psi straight across. When I retime it, what octane can I get by with? 87, 92, 93 or ?
BUDD
06-04-2005 16:42:26
 Re: Gas Octane Necessary in reply to jhb, 06-04-2005 02:09:55
You want just enough octane to keep it from spark knocking any more is just a waste in my opinion.
BUDD
jd b puller
06-04-2005 15:05:52
Is it stroked, bored, etc???
ChadS or someone could confirm, but wasn"t the stock engine meant to run on about 65 Octane? The main reason we run the high test gas isn"t just because it needs 110 Octane. Detonation is probably the real killer of most of the stroker cranks and we"d rather spend a couple extra bucks and maybe lose a couple horses on the higher octane than take a chance of spark knocking. MOST of them would probably run just fine on 92-100 Octane, but cranks is expensive and in reality, gas is cheap (even at $4.50 a gallon!!!)
caseyc
06-04-2005 05:24:26
what kind of farmall? 4cyl or 6cyl? i'm not sure on the 4cyl but i know the 6cyl needs 92/93 octane.
casey
