A little too much
jd b puller
06-02-2005 20:20:57
I got a little agressive on the head for my B. Anyone got any ideas how to repair it? UNDER the valves, in the pocket, on the top side (as it sits) I broke thru to the water jacket.
ChadS
06-03-2005 07:34:14
 Re: A little too much in reply to jd b puller, 06-02-2005 20:20:57
I hate it when that happens!! Depends on if it has fire, or air fuel going past it. If its the intake side, you may be able to JB weld it, exhaust, you can braze it, weld it, but still may leak, maybe silver solder,,,,, Mite think about finding another cyl head till you figure out what to do?? Most welders get good $$ to do repairs like that,, so be warned.. Chad
jd b puller
06-03-2005 15:12:58
 Re: A little too much in reply to ChadS, 06-03-2005 07:34:14
It"s on the intake UNDER the valve. Not in the combustion chamber. Somewhere in the intake runner it is sucking water. Fortunately, I didn"t have the engine running when I was adding the water or I think it would have made a real mess. It filled up both cylinders and then came out the carb!!!
